Originally Posted By: 01rangerxl
Originally Posted By: Mr Nice
Nice. But what else needs replacing / worn out ?
If it's directly related to the transmission rebuild or R&R, Ford should cover it.
Either way, I wouldn't complain about a no charge trans at those miles.
Are they actually rebuilding it? Hopefully a rebuild totals it out and they put in a reman. I'm not a huge fan of building transmissions outside of a transmission shop that has a clean room. They do need to be built in a clean, careful environment which is often not what a dealer service department is. I work at a GM dealer and it seems like a lot of the transmissions we build fail in short order...and the guy that does them is very smart and very conscientious. I don't think it's him, I think it's trying to build a trans in a shop that's simply not clean enough to do it right. Thankfully they usually total out and we just get a GM reman, or in some cases a brand new transmission.
While building in a clean climate controlled build room is very nice. However....For most units, Especially GM ones, It is not absolutely necessary.
ATF soaked parts attract dirt & debris, They need to be blown off with CLEAN solvent, Then blown dry, Dipped in fresh ATF then immediately installed in the case.
We have to change our build techniques for different environments, In a clean room you can clean everything at one time, Lay in all out on a bench, Then start assembly.
In a dirty environment, You have to clean, Assemble, then Install each component separately while keeping the Case covered at all times, Always clean the Control Valve Body last using New Clean Solvent. If the Tech at your dealer has to share solvent & the part washing machine with everyone else in the shop.....That is a big issue!
It is a much supported myth that Frictions just wear out prematurely, This is 100% untrue, When you get a unit in with a Burnt Clutch.....Something caused it, Like Leaks in the apply circuit, Slow Apply/Release, Low/No Pressure rise, Low Pump Volume/Pressure etc.
Point is....Throwing Frictions at a problem is not a solution!
