Originally Posted By: GuinnessGuy
Here is a link to the Dexos 2 approved oils in the US and everywhere else. http://www.centerforqa.com/dexos-brand2/
Interesting list that looks like a VW one, as it approves any old company that applies.
Things went downhill after Acea A3/B4, although Brexit will mean the UK will dump the Acea game and go with API!
There is no cheap answer to reduced Zinc based additives causing higher wear metals (Mostly cylinders). Ceratec (DPF approved) is not cheap.
