The 40 gallon gas water heater is about 8 years old and is the older non power vent style. Problem is, if I don't use any hot water for maybe 12 hours or more, and then I go to use a lot of water, it only produces about 1/2 the volume of hot water it should. If I use it a few times a day [dishes, laundry, shower] I never have a problem.
Is this normal? The thermostat is mounted low in the tank so I would think it should fire up before I have any kind of problem.
Any ideas?
Any ideas?
