Originally Posted By: Shannow
Other bad stuff happens, like acid formation, dilution, soot loading that must be gotten rid of.
The Paradise garage sampling study showed that even taking out and replenishing a blackstone bottle's worth every 1,000 miles, the oil reaches an equilibrium.
Maybe taking half a sump out every 3,000 miles, and doing a perpetual OCI filters every 15-20 is the most technically correct way of running.
I'm still researching.
I'd suggest to save your used oil, decantle it and reuse. The settling would make the insolubles (including soot, some harmful acidic byproducts from oxidation like betumen material having water afinity, excess metalization and dissolved varnish) to separate from suspension and deposit at the bottom of the container. Since half sump would keep much fine dirt in sump.
