I found
2 quarts of Mercon V Motorcraft "Transmission and Power steering" both opened but full (?????)
12 oz bottle of Mercon V Motorcaft "power steering" Im assuming same as above
12oz bottle of Motorcraft brake fluid DOT3 (half full)
1 Quard of Toyota T-IV. Also opened for at least 2 years. Cap sealed tight.
Im going to guess these containers have been open for at least 2 years. I dont really even have anything anymore that uses Mercon V. Dextron 3 and T-IV are my applications. Are these even good anymore for how long they've been open - should I dump it with my old ATF fluid?
What about the Brake fluid. That cap was sealed pretty tight. Could I mix it with Prestone brake fluid DOT3 (Fresh)?
Lastly, GS300 takes T-IV. Drain and refill with Maxlife okay? I asked Valvoline and they said it meets T-IV. Could I use up that T-IV I already have and fill rest with Maxlife?
Lots of questions I feel I shouldve made seperate threads.
Thanks all for input.
