ok using a clicker torque wrench while removing a lug nut will not tell you what torque you are at
breakaway torque is ALWAYS higher
this is why impacts always have significantly more torque in reverse than forwards
also torque sticks have a sweet spot for the gun... using a torque stick with an IR231 is usually just fine, using it with an Aircat 1150 maxed out (iirc 950ft-lbs forwards) is a bad idea
