Running 5W40 Motul 8100 Ex cess in my 2000 Concorde 2.7 with almost 130K miles. On a road trip and smelled oil at a stop and decided to check the oil which was full a few days ago. A full quart low and notice some oil spray on the frame rail, so it has sprung a leak. Put in a quart of Mobil 1 0W40 which brought it to a half quart low. Don't know if the oil pan or rear main seal is leaking. Neither makes sense to allow oil to get on manifold mounted converters or on frame rails next to engine. I'll have to pressure wash the area, then run to see where it is coming from when I get home.
Should I reduce my oil change interval since I don't know if the additive package or base oils of the top off meshes well with the Motul fill, or don't worry about it. I usually do about a 5-6K interval with 229.5 oils in this engine and all looks clean through the fill cap. I'm at about 2K miles on this fill of Motul.
