+1
It really depends upon the engine.
Most all iron engines will survive this sort of mistreatment pretty well.
No all alloy Honda or BMW will and engines with alloy heads on iron blocks will fare even worse.
Run the thing for a week and a few hundred miles. You may have to top up the coolant due to air purging.
If after a bit the engine seems fine, then change the oil.
No use wasting a new oil and filter on an engine that needs a teardown at the least.
