Originally Posted By: Rand
windows 10 runs fine on my 1GB tablet.. I wouldnt bother upgrading memory past 4GB
or spending over 50$ fixing it.
Memory errors can also be caused by motherboard.
Which memory chip was bad since you have 2 you can pull 1 and retest each 1 at a time.
If both test bad.. its probably the motherboard.
8GB@70$ is a good price but still expensive
considering ddr4 is down to 16GB for ~50$
FWIW Windows 10 memory minimum system requirements are...
32 Bit = 1GB RAM
64 Bit = 2 GB RAM
OP's system is a 64 bit so he needs at least 2GB. Maxing out to 8GB would help a lot and seeing as it is under $70 to do so it is a no brainer to me.
32 Bit = 1GB RAM
64 Bit = 2 GB RAM
