Originally Posted By: motor_oil_madman
I had my truck in at the shop a couple months ago and had them replace both upper/lower ball joints and inner and outer tie rods, so I would have a nice tight front end that wouldn't eat my $500 dollars worth of new tires. I believe and I've probably put 1500 miles on it since then and I haven't put new tires on yet, but you can see the outer 3" of the tire is wearing badly compared to the rest of the tire. Now these tires are already shot, but you can easily see the wear. Why can't shops just set the tires straight ahead? Ever since I've had this truck it has always worn the tires unevenly in a weird way. Think of like a slanted roof. The tires stayed worn evenly, but the entire tire itself wore at an angle. This time it's actually the shoulders wearing on both front tires. Do I just bring it back and pay another $75 to have them align it again? I would think their would be some kind of warranty
The front tires need a little Toe-In per the Alignment Specs, Though Tech's/Shops rely on Alignment machines more than they should, Back in the "old days" we would physically measure the Total Toe-In while on the Rack & after a test drive to make sure nothing shifted.
I don't know the toe specs on your truck but 1/8"-1/4" Total Toe is norm on most fullsize trucks Pick a spot on the Thread & measure the distance between both tires on the front then the back of the front tires, The Difference will be the Total Toe.
Towing heavy loads that drops rear ride height/raises front ride height WILL Alter the alignment settings.
Making constant tight turns (U-Turns) with alot of Positive Caster....Will wear tire at an angle, Especially with a heavy engine like a Cummins B-series....
Back in the 60's though the 80's, Most heavy duty truck alignment specs called for 0 Caster & 0 Camber......They drove like $hit, But people didn't have the driving dynamic expectations they do today out of a 3/4 ton/1 ton truck, Even though the steering/suspension geometry hasn't changed much. I'm guessing this is a 2wd Dodge? Save for the Rack & Pinion, It has the same Long Arm/Short Arm style suspension that came on a 1960 Chevy pick-up (Ford & Dodge still used King-Pin Straight Axle at the time)
