Just out of morbid curiosity, what is it about an SF oil that's (allegedly) likely to kill a post-88 car ... and what failure mode would be expected?
Originally Posted By: circuitsmith
Newer designs have hotter hot spots the oil encounters as it circulates through the engine.
OK, that makes sense. Thanks for the reply.
Narrower rod & main bearings,
Can't see that. If bearings are getting hot enough to break down ANY oil then they're broken.
tighter ring packs nearer the top of the piston (reduces the crevice between the piston and cylinder, which reduces HC emissions),
also there's more HP per displacement, which makes more heat and stress.
Not sure I see that either. It describes a generalised input of heat into the system, rather than a hot spot. Provided the cooling system is adequate, generalised heat input shouldn't lead to higher general temperatures, so shouldn't break down oil. If it makes the hot-spots hotter, that'd do it.
There's also more complex valvetrains to protect.
Daresay, but I don't see why a complex system is harder to lubricate than a simple one, though it may have more failure points.
I suppose hydraulic tappets and chain tensioners are a specific oil-vulnerability but I think they existed pre-1988, though probably got commoner after.
I wonder if the increase in [censored] plastic chain guides has anything to do with it, but I think they existed pre-1988 too.
