Originally Posted By: SilverC6
It's funny that in the case of the Purolator tears, all the flow going through an oil filter magically travels through a single 1/4" tear.
Now with this new louver fiasco, no flow can negotiate its way through these tiny little louvers.
What's the factor of safety in the Purolator design on the number of louvers punched in the tube? 2? 2.5?
Put 5 quarts of oil under pressure on that louvered tube and see what rate of flow is achieved.
How do the louvers compare to the media permeability in flow rate? Which is more restrictive?
You guys sure know how to burn some witches.
A little knowledge is a scary thing.
SilverC6 - there is no good way to rationalize this as being good. This is what you are trying to do.
In this case since the witch has failed to make good witches brew, the witch would be burned by the other witches.
This is not a witch hunt. Funflyer is reporting facts.
