Originally Posted By: George7941
Originally Posted By: CapriRacer
I know of no vehicle manufacturer that doesn't use hub centering.
A true hub-centric wheel uses lug nuts with a flat flange that clamps against the rim. Heavy and medium duty trucks use hub-centric wheels.
Wheels using conical lug nuts are lug-centered, in other words, most car wheels are lug-centered. If they were not lug-centered, the lug nuts would not be able to properly clamp the rim on to the hub. So I have to disagree with CapriRacer.
My Sierra rims use conical lug nuts and also the rim centre hole fits snugly on to the hub, so perhaps this is an instance of a wheel being both hub-centric and lug-centric. But I still stand by my statement that any wheel using conical lug nuts is lug-centered.
I would have to agree 100%. A 60 degree tapered lug nut, is where the clamping force is, regardless of the hub. Most Toyotas, and older F150's are the only ones without tapered lug nuts. Hub to mismatched bolt circle interference is why studs break sometimes.
