Originally Posted By: TTK
Seriously? No one can tell which are open and which are closed(if any) from these pictures. If you want to prove something, cut the filters and remove the tube then take pictures.
A virgin cut and post would be more clear. The open surface area could be estimated. The distribution of the louvers and the open areas could be mapped. If the open areas are not at least as good as holes, then this is a filter failure due to manufacturing defects.
The first pass, non-destructive inspection is needed for all installers, PRO or DIY.
I am skeptical the quality is there for better grades of Purolator filters. This includes the often praised Motorcraft filters.
The BITOG community is catching way to many issues with Purolator junk filters.
And thanks to funflyer for making the thread.
