Hello all. I am sure that this has been discussed before, but I will ask anyhow. Has anyone researched the difference between Honda DOT 3 brake fluid and conventional DOT 3? According to the owners manual it says you can use a standard DOT 3 as a temporary replacement but must be changed out to the Honda stuff ASAP. That said, I get the fact DOT 3 standard is a "minimum" the brake fluid has to perform to, but does anyone know if the Honda stuff exceeds the DOT 3 standards? Such as extra additives? I
