Originally Posted By: stephen9666
I wonder if they'll run well on cheap gas, especially in summer?
I overall like my Cruze Eco with a 1.4T, except that it runs like garbage in the summer on 87. I know some other turbo engines have similar issues. 87 is the minimum recommended in the manual. It's somewhat improved with higher octane, but that raises the cost per mile in what is supposed to be an economy car.
In the future I'll be doing a lot of research on that issue.
Also, small turbos are sometimes better at gaming the EPA fuel economy tests and may not deliver in the real world.
Mine's been cheaper per mile to run on premium than regular. Between that and the improved warm-weather response, it's a no-brainer for me. These particular engines are well-known to run poorly on 87 in the summer, especially with the A/C going. Try running a few tanks of premium from a station with a good amount of turnover, and see if the cost per mile is the same or less.
Mine at 132k miles hasn't yet had any turbo-related issues. Then again it's had full synthetic oil changes at 7500 mile intervals since brand new.
Being a Honda, I would expect it to be just fine mechanically assuming the recommended maintenance is carried out on schedule. Doing that is key to these small, power-dense turbo engines. Skimping on maintenance is guaranteeing a larger bill down the road when that deferred maintenance catches up.
