Looking to find a procedure or video on this and came up empty last night after 2 hours of Googling/Utubing it. Various Lincoln forums don't have any threads on the 1996-2002 Continental valve covers. Town Car and LS maintenance info is all over the place. First time I've run into a wall when trying to hunt information down.
Already found all the information I need for the serpentine belt, idler puller and tensioner replacements. All that's left to research is the source of the leak that caused damage to my drive belt (highly suspect outer side of front valve cover gasket).
The front valve cover looks quite accessible. Don't see why it wouldn't come off in about 15-30 min. Only interference is a coolant hose connection and ignition wire cover. The coolant hose is about level with the system high point vent fitting. Any inputs would be appreciated to make this go smoother. Can't see the exact source of the leak on to the serpentine belt but the inner side of the VC gasket is moist. It might be possible that the power steering hose in that area could be weeping on to the belt.
When in there would new spark plug tube seals be required? Sealant on new gasket or just use dry? 71K miles so this will be the first time seeing how clean it is in the upper engine. Might as well check a spark plug for reference.
