2005 Chevy malibu max. Sometimes when I brake coming off an off ramp my driver side suspension seems to bounce up and down very fast and it sounds like it's coming from the struts. I just put on all new rotors and brake pads over the weekend and yesterday I had the car at the mechanic for the same loose sounding issue. He said the tie rods where loose, replaced the sway bar bushings and end links as well. Any idea what else this could be? It's been going on intermentantly for some time. I also just had new tires put on last week as well. Th best way to describe it is like the rotor is very warped. Thanks!
