Originally Posted By: puredata
I'm looking for a pair of pads for my fronts on Scion xB 2010. I didn't want to start a new topic since this one seems pretty related. Right now, I have ordered Akebono ProACTs but I'm planning to return them. Here is why;
I was about to buy Toyota/Scion OEM pads for $66 but after reading that they are ceramic pads I decided to go with Akebono since lots of people are using them happily and they were $45 and probably the OEM supplier for Toyota. But after further investigation I saw that main reason people are happy with Akebonos is no brake dust, even though they have less bite than OEMs.
I don't care about brake dust. No matter how much, especially by sacrificing my brake power.
Anyway, I have made some research and found out that Akebono ProACTs has FF performance rating. I live in a pretty cold climate, do you think that I should stick with those pads or should I return them and order OEMs or HAWK HPS? I heard that ceramic pads might perform worse while they are cold.
Or is it enough for my '10 xB with 135k? I do highway driving everyday about 20miles but time to time it's snow covered.
Thanks for responses in advance.
Toyota uses multiple suppliers - usually it is Akebono, Advics and NBK. But lately, it is usually Advics and occasionally NBK. Akebono is becoming less common for Toyota.
The ProACT is Akebono's aftermarket line. Compared to most aftermarket pads (especially ThermoQuiet), it is a pretty good pad. Low noise, good pedal feel, reasonably low dust. Doesn't chew up rotors but does tend to leave heavy dark deposits. The service life can sometimes be poor on heavier vehicles (e.g. Highlander/RX). They also use the single-layer shims (not the heavier duty 2-piece OE design), but for some reason this seems to work okay since the pad material is very quiet.
However, if you are a very discerning driver, you will probably find that the ProACT pads have a smoother and more progressive feel than the OE pads. I have installed quite a few sets of the ProACT pads and many sets of OE Toyota pads (often in the same application) and can tell you that the OE pads will have a sharper initial bite. Some people like this (I do), some people prefer the smoother feel of the Akebonos. You have to be a very discerning driver to notice, or you have to drive the same car back-to-back.
The OE pads for your car are part #04465-42160 and the required shim kit is part #04945-12110. MSRP for the pads is $99 and MSRP for the shim kit is $37. The notes say that the OE pads for your car are the Advics.
Also, the dealer may try to sell you a "Toyota Complete Maintenance Care" pad kit. These pads are similar to the ProACT pads but tend to be noisy. Here's some info on the differences between the two:
http://carspecmn.com/toyota-complete-maintenance-care-brakes-vs-toyota-factory-brake-replacement/
