Originally Posted By: ragtoplvr
Originally Posted By: mk378
From the ebay listing:
"Features: Use with older points style ignitions"
You should not need a resistor except with points. The resistor is mostly to limit current to keep the coil from burning out if someone were to leave the key on with the engine not turning and the points closed. Electronic ignitions do not flow current through the coil unless the engine is turning.
Wrong. The ballast resistor was bypassed during starting for a stronger spark. Many older solenoids have a "R" terminal hooked to the coil during starting.
Rod
Correct. The coil may only be a 6 volt coil and depends on the ballast resistor for normal operation. The trick with ballast resistor bypassed during cranking works because the battery voltage is reduced while the starter is cranking and it's only for a short time. Also, electronic ignitions can use ballast resistors just as points do. My MG had factory electronic ignition and used a ballast resistor.
