Originally Posted By: philipp10
depends upon tire wear. On modern well aligned cars.....I just don't see the point. I rotate every 30k...are you stuck in the 70's?
I stopped rotating years ago for the most part. Light PU trucks that get a lot of slipping on the back may be an exception.
Rotating tires wearing well lessens traction in my mind because the tires have 'seated' to the road surface after a bit of wear.
