This is on our 2008 Honda CRV. I need to replace the rear rotors along with pads since there making noise. Does brand really matter? Obviously I want them to last.
You may or may not need to replace them. Many people just do a pad slap if the rotors look good (the surface is pretty flat) and there was no pulsation.
You need not spend a lot on rotors. Get good quality rotors and excellent pads. I go for Akebono Pro-X Ceramic if available.
Pretty much all of them are manufactured in China these days. I like the Centrics on my Acura TL front and rear. OEM is overpriced and won't last any longer than the Centric stuff from Amazon, IMO.
I just put in a pair of front Wearever rotors from AAP, $58.09 before tax on a 2008 Honda Accord. Used code trt41 and add a CQ oil filter. I use Wagner ThermoQuiet QC787 Ceramic Disc Brake Pad I had sitting around since 2014 which I got for $17.71. Total with tax $80.38. OEM rotors had pulsation/vibration when braking. New rotors and pads solved that.
Last year, I put on the same front Wearever rotors and ACDelco pads on my 04 MDX. Still works great. Cost was $86.36.
Centric Premium rotors are $33 on Amazon and Raybestos Professional Grade rotors are $26.
I'd pay $90 (and have done so). Works first time, no issues with thin chinese pot metal. As long as they last >100k along with the pads (ideally much longer) I'm fine with it.
What sound are the brakes making
The passenger rotor had a what look like a burn mark around the rotor. I inspected the pads and the trailing edge was flaking off. I cleaned both the rotor and pads but the noise came back two days later.
I don't know about aftermarket brake rotors but my experience with aftermarket brake drums was such that they were junk -- ill-fitting and fast-rusting.
I use OEM as a minimum, and typically try to get better than OEM brake parts. Better varies depending on what you are looking for. OE is typically pretty well optimized for general use.
I have a 2008 accord which is known for rear brake issues.
I went through 2 sets of duralast rotors before I bought the centric premium rotors with painted hats.
They have been doing great no issues.
I am using duralast cmax pads on front and rear.
