Originally Posted By: Jarlaxle
Immediately, as in now, check cam chain tensioner shoes!
+100 I had a 2006 Dyna Lowrider. You should check the cam tensioner shoes at about 20-25,000 miles. You drop the front exhaust pipe and pull the right cam cover off. Not a big job as the gasket costs about $10. But it is important to check both sides. If you get a $2 dental mirror you can see the inside one and no disassambly is needed beyond that. But do also get a new donut gasket for the exhaust pipe. Yo will lose about 4oz of oil when you remove the cover.
If you are really handy while you are in there you can check the runout on your crankshaft with a dial indicator. Probably a good idea.
If you don't want to check them...then at least cut your oil filter open and look for shards of orange/yellow plastic in the filter pleats. IF YOU SEE ANY OF THIS YOU NEED TO DRIVE YOUR BIKE TO A DEALER AND HAVE THEM REPLACE THE TENSIONER SHOES RIGHT AWAY.
Not a hater joke...just a fact with the TC engine design.
Oh yeah...put gear oil in the trans. Any gear oil will do and it will go 15-20,000 miles between changes.
