Originally Posted By: The_Eric
Originally Posted By: Colt45ws
There is a place advising using a very high torque value on the spark plugs to prevent them from loosening, but, Ive checked and the stock value of 10ftlbs is about all you want to give a 4-thread head. Taking into account the strength of the cast aluminium.
An 8 thread head is much better in that respect, and 18-22ft-lbs is doable. So, I did tighten the plugs on the F150 to 18ft-lbs.
The place you're referring to tested a head to 100lbs without ripping threads out- I think it'll handle 28lbs just fine. I've done several this way and ALL have felt rock solid.
Yeah, and I found a bolt torque calculator and ran through a few different numbers and 11 or 12 was all it would give the heads with 4 threads, IIRC.
