I want to thank you for this trick. I used it on my Protegé5 last weekend replacing the upper radiator hose.
Worked like a champ.
Thanks!
Originally Posted By: DBMaster
You first put the spring clamp over the radiator hose neck, then push the hose on. Then, you only have to expand the clamp enough to go over the hose, not the barb.
That's only if you run into this type of issue.
Thanks!
