This is my first time on this forum and I was fascinated by Bob's thorough explanation of viscosity and the fundamental differences between mineral and synthetic oils in maintaining their viscosity.
But it raises an interesting question...
If the lower number is a measure of an oil's ability too flow at colder temps and the higher number is a measure of its viscosity at operating temps, why used anything higher than 0W at allis using a synthetic? What can be the harm in having an oil that is at least closer to the 10 flow rate when cold, as long as it has the same when hot?
I have an Indian Chief Vintage, which is notorious for having a sticky gearbox when cold, and it is because the clutch plates get gummed up with cold oil in the first few minutes of operation. (Indian Thunderstroke engines have a shared sump with engine and gearbox, so they do want a specific motorcycle oil that does not have the friction inhibitors,but that seems separate than viscosity).
As well, if Bob is correct (and I think he is!), why do manufacturers persist in recommending 10W or even 20W (in the caae of Polaris/Indian) if the science shows that flow rate is too sluggish? And why does Indian (or others) recommend a blend?
