Gokhan Joined Dec 29, 2010 Messages 5,889 Location Paramount, California Jun 6, 2016 #21 Try the GM OE ACDelco cooling-system seal tabs (ACDelco 10-108/GM 12378255). It worked in my Corolla. http://www.acdelco.com/auto-parts/vehicl...-seal-tabs.html
M MaximaGuy Joined Sep 20, 2003 Messages 1,713 Location Austin, TX Jun 6, 2016 #22 There is a UV dye you can drop into the cooling system that can be observed in the oil if there was a leak from the pump. I used the dye to determine my car had an leaking pump.
