Castrol Edge High Mileage 10W-40
Great Lakes
Batch number: X153071
Lab: Wearcheck USA
Sample date: 5/27/2016
Text version (just in case images above ever disappear):
Silicon 5.4
Potassium 2.2
Water (%)
Boron 370
Barium 0.0
Calcium 3097
Magnesium 10
Molybdenum 75
Sodium 2.8
Phosphorus 700
Sulfur 3068
Zinc 738
Visc@40°C 91.52 cSt
Visc@100°C 14.6 cSt
Visc Index 166
Oxidation --- ---
TAN 1.62
TBN 10.0
Iron 1.2
Nickel 0.5
Chromium 0.1
Titanium 14
Copper 0.0
Aluminum 2.8
Tin 0.0
Lead 0.0
Wow. And "Wow!" one more time. More than 3k Ca, 370 boron, TBN=10... Very impressive, thanks a lot. Just curious if xW20 and xW30 versions would have same additive pack.
Agree. If 10W30 has similar additive pack I will use it in my 2004 S2000. Currently I have Maxlife full syn 10W30 in it.
May be get 1 jug each to mix half-and-half. The car doesn't consume measurable amount of oil during OCI's of 5-6k miles, 2 jugs will be good for 2 OCI's.
Wow is right! Look at all that boron and calcium. I could run that stuff a whole year in my Jeep with that TBN too.
Thanks for having it tested!
Been eyeballing the 5W-30 flavor ever since it showed up at my local Walmart on the shelves. With all the rebates going on for Mobil and Pennzoil lately, I just could not see myself buying it with all the discounted all for sale. This VOA has me thinking really hard now. It's impressive on paper.
Not that impressed by this. It's A3/B4 so you knew it would have a high TBN. The zinc is about 200ppm lower than M1 HM 10w40 though.
+1.
Appears to have strong detergency but weak-ish anti-wear?
If M1 HM 10w-40 met ACEA A3/B4, I would have probably bought it instead.
I'm just disappointed (well, not really) that there is so little titanium in this Edge HM. I thought Edge HM was supposed to have a decent amount of it.
It has a splash of Ti, a decent shot of moly and loads of boron. I'd hardly call it weak on anti-wear.
All the A3/B4 oils in the US have 1000-1100 ppm (or near it) of zinc. Why they would short change this one makes no sense to me. ZDDP is still the king of antiwear additives.
Is this for a DI car? Because for that app, I could see choosing A3/B4 preferentially. But for non-DI, I like the M1 HM 10w-40 better w/it's A3/B3 rating.
Nope.
I was just looking for an HM oil that is still somewhat close in performance to an LL-01 oil, and the LL-01 spec is baselined on ACEA A3/B4 spec.
A3/B4 has stricter wear and cleaning requirements compared to A3/B3.
Well, I believe the regular Edge has 7ppm of ti, so 14 is more. The most is found in Edge EP, which is around 23 ppm. Keep it mind this is BP's own proprietary Ti additive and is not the same as what CP uses in the Kendal line.
Nope.
Well, it certainly is beefier than many oils on cleaning, but it's a lot weaker on the anti-wear than some A3/B3 oils. Must be a lot of variability between brands. I guess this would be a good DI car choice, though.
Too much calcium for a DI engine, IMO. Supposedly this contributes to LSPI.
Comparison of M1 HM 10w-40 (tested in August of 2016 by member SubyRoo) against Castrol Edge HM 10w-40.
Granted, different labs were used, so it's not exactly apples to apples comparison...
Code:
Element M1 HM 10W-40 Edge HM 10W-40
Aluminum / 0 2.8
Chromium / 0 0.1
Iron / 0 1.2
Copper / 0 0.0
Lead / 0 0.0
Tin / 0 0.0
Molybdenum / 69 75
Nickel / 0 0.5
Manganese / 0 0.1
Silver / 0 0.0
Titanium / 0 14
Potassium / 0 2.2
Boron / 85 370
Silicon / 7 5.4
Sodium / 5 2.8
Calcium / 958 3097
Magnesium / 680 10
Phosphorus / 794 700
Zinc / 914 738
Barium / 0 0.0
SUS Visc @ 40C / - 91.52
cSt Visc @ 100C / 14.96 14.6
Visc Index / - 166
Flashpoint in F / 440 -
Fuel% / - -
Antifreeze% / - -
Water% / 0.0
Insolubles% / 0.0 NEG
TBN (mg/KOH/g) - 10.0
TAN (mg/KOH/g) - 1.62
M1 tested by Blackstone.
Edge tested by Wearcheck.
I'm confused, the Mobil 1 10W-40 HM DOES met A3/B3, doesn't it?
At least, that's what it looks like, according to Mobil 1's website.
It does. He hasn't said that it doesn't.
