Originally Posted By: momo
For those who are wondering about other numbers from the emission test, here it is
The fact that your low speed and high speed HC numbers are nearly identical means that you have a problem with a part on your car, causing the ignition process to not be completed fully.
Since it's happening at idle speed and at 2500 rpms, I'm going to rule out carbon deposits causing pre-ignition or egr clogging.
You're looking at weak ignition caused by either an ignition coil going weak, or a spark plug not fully igniting the mixture in one or more combustion chambers due to a bad spark plug, spark plug wire, or a burned contact in the distributor cap.
If it were my car, a completely fresh set of ignition components would be step 1, including the ignition coil.
Since you're not me, and are a cheapskate, you can do something else, in stages:
For you, step 1 should be drive the car, get it good and hot, and go to the test facility while good and hot.
Step 2 - If that doesn't work, drive the car until all the current fuel is gone, then add in several gallons of brand new fuel. Go back, retest the car, and see if you pass.
Step 3 - If those two tried fail, next step if to buy a bottle of fuel system cleaner, like Techron Complete Fuel System Cleaner, add it to the tank, and a few gallons of gas, drive the car until all of it has been burned, then add a few more gallons, and go retest to see if you now pass.
Step 4 - Post what your emissions score is at this point. If it looks exact the same as this one you already posted, then you now know you HAVE to inspect your car to see what parts need to be replaced. Start by pulling the spark plugs. Is one fouled? If yes, since you are so bloody cheap, swap it with the one in the next cylinder. This way you can then determine if the problem stays with that cylinder (spark plug wire, distributor cap, cylinder related issue, etc), or if the problem follows the spark plug (guess what you need to replace if this happens). If you get the car running better, go retest.
But you need to remember, you're cheap. How much does it cost you to keep retesting the vehicle if you fail it every time? How much more is the car worth if it passes the test? How much will gas cost if you keep having to buy more of it to keep driving around and retesting the car, and getting new parts, or running cleaners through the fuel system?
Ultimately, if you can't afford to fix the car, you shouldn't even have bought it in the first place. I learned this lesson back in the late 90's when I bought a 1982 Monte Carlo with the 229 Chevy V-6. I couldn't get that car to pass Colorado's emissions tests at the time, and I was throwing parts at it, and they were not having the needed effect. I wound up junking the car, and losing all the money I had put into that pile of crud over a year long period of my life, when I needed every one of those dollars I spent.
BC.
