Different tires have different performance parameters and wear differently...I had what were really summer UHP tires (despite being labeled A/S) and wore perfectly evenly @ 44psi on the Camry spec'd for 29! Their max was 51psi.
The current Cooper CS5 UltraTouring (touring), max rated @ 44psi, are wearing evenly @ 32-34psi...
Should be noted that the Camry's OEM tires were 15"ers, and I'm now running 17" rims so that may account for the difference.
Why would you run them at 44 if the placard specs 29? That seems a bit odd
That generation Camry is considered the softest, most "floaty" cushy iteration....increasing the rim size, running ultra-high performance summer tread at a higher psi gave me a very firm and sure ride...it was stable in all conditions, and as reported, gave me even wear at 44psi....the Camry only weighs 3100 lbs.
I just looked up the 2005 Camry owners manual to satisfy my own curiosity.
The 15" rims on the LE spec a P205/65R15 with 29psi front and 29psi rear.
The 17" rims on the SE spec a P215/55R17 with 30psi front and 30psi rear.
So the 10mm wider tires on the factory 17's spec 1psi higher inflation pressure. Load capacity, contact patch, wear pattern, ride and handling, are of course all factored in by Toyota here. This is in-line with what I said earlier regarding 15psi being massively too high for the small increase in width.
There is also a note about periods of sustained high speed driving:
Originally Posted By: Toyota
When driving under the above vehicle conditions at sustained high speeds above 160 km/h (100 mph), in countries where such speeds are permitted by law, inflate the front and rear tires to 240 kPa (2.4 kgf/cm2 or bar, 35 psi) provided that it does not exceed the maximum cold tire inflation pressure molded on the tire sidewall.
This is due to the heat generated, which can cause tire failure, something that is mitigated by the higher inflation pressure. This is also covered on Barry's site. Amazingly, even then, Toyota doesn't recommend 44psi, or even mention it. And I assume the size above is the size you are running.
There is then yet another table that covers trailer towing. They again recommend increasing the pressure due to the additional heat generated, and to 32psi for both the 15 and 17's. The 16's continue to have the 29psi recommendation.
This should all be in your owners manual.
