Originally Posted By: asand1
I would use a garden sprayer to spray a fine mist. Even better would be methanol washer fluid sprayed while under load. I have often thought about buying a wrecking yard washer bottle/pump and irrigation misting nozzle to do a hard install for cleaning/antiknock.
Yes, exactly this.
There are nooks and crannies between my throttle body and intake valves, though, that water might accumulate in. I get a funky knock on the "road test" afterwards but no permanent damage. It's enough to worry about, but not enough to stop me.
If you have a plastic accordion intake for example there are lots of pockets water could sit in.
Yes, exactly this.
