Originally Posted By: bigt61
IMO the engine will break in better if you leave the factory fill in and follow the OLM. I would also stay with a semi synthetic until 30k and then switch over to full synthetic. I feel these modern engines and their low tension oil rings have a hard time seating with early changeover to full synthetic.
While doing some general engine lubrication research, this time on aero lubes for piston engines, it seems that most do not want any synthetics in there for the first three oil changes. Only dino oil. Then you MAY be free to use syn-blend. This is from a couple of sites including Blackstone's discussion of aero lubes ...
I personally have never been a fan of pure synthetics. But now even Mobil Aero is listed as a blend with no mention of PAO or the word synthetic in their blurb. It obviously has some GrpIII (+) in there as it's a full 15W-50 oil.
Point being that both OEM MFG's and reputable re-builders of piston aircraft engines seem to specify dino oil for break-in. SOooo, if I was in your shoes, I'd be likely to only go premium blend. I'd do early changes and add magnetic drain plug, but no full syn for while ...
