Are the viscosity readings most likely an error by the lab? For this OCI and the one prior (10/24/2015) I ran Honda OW20 syn. This is a direct injection engine so that might explain some of the fuel. The wear metals look OK to me. I did find the drop in moly a little curious.. is it normal for additive levels to vary like this even using the exact same oil?
The oil is sitting in a catch pan with brake fluid and other oil, so no chance of a re-test.
