Originally Posted By: 69GTX
Originally Posted By: Noey
You have too much time on your hands.
50/50. It optimizes the heat transference properties of the glycol, as well as optimizes the anti corrosion benefits.
There's no optimizing the heat transfer capabilities of the glycol. The higher % of it you use, the less heat transfer your engine cooling system gets. It's 2 major functions are to lower the boiling/freezing points and provide some anti-corrosion chemicals. If heat transfer was all we cared about, we'd run straight water with anti-corrosion chemicals (ie like Water Wetter).
Oops. Meant to say raise boiling, lower freezing points.
