1 FMF
Eaton's very own tech info specifically warns against certain fluids with FM and/or syns when using the TrueTrac.
Additionally, our vaunted member (who has faded away due to other committments), Jim Allen, who is a noted technical automotive writer and avid 4x4 enthusiast with decades of experience on the "trail", also specifically warns against such fluids in the helical gear diffs.
Also, I have actually emailed them over this very topic, and received input as to why to NOT use syns/FM in this application. Syns and FM are tolerable, but they will most certainly alter the operation of the unit.
Detroit Truetrac®
High quality mineral or synthetic gear lubes are required for use in Detroit Truetrac differentials. Regardless of the lube type, always use a GL5 rated lube with the least amount of friction modifier. Mineral lubes lacking friction modifiers (limited-slip additives) were historically recommended for all Truetrac applications because friction modifiers can slightly reduce the bias ratio (limited-slip aggressiveness) of Truetrac differentials. However, to address the continually increasing power outputs of modern
powertrains, many vehicle manufacturers have switched to synthetic lubricants as a counter measure for increased axle temperatures and prolonged service intervals. In general, consult the vehicle owner's manual for the manufacturer's recommendations for lubrication type, weight and fill volume. This will ensure lube compatibility with the seal materials and bearings used in the axle. Eaton Performance technical support is available for any concerns in lube selection.
Taken from here; page 25 of the install/op manual:
http://www.eaton.com/Eaton/ProductsServices/Vehicle/Differentials/detroit-truetrac/index.htm#tabs-4
Yes - they do allow for the use of syns and FM. But they are not advisable nor desired. They are, shall we agree, tolerated in the application. They will, most assuredly, alter the bias of the LSD device, which relies on the CoF for operation and resultant application force. Will the device work with syns and FM additive? Yes. Will they work at their maximum efficiency as designed? No, they will not.
Why do we use lubricants? To reduce wear. To that end, if you can have a fluid that achieves the task, and do it for the least cost and least risk to performance, why not use that fluid? Looking at the SAE J2360 approved list, there are dino fluids that do meet the spec, that don't have FM, that are not synthetic. Why pay for a lube that will cost more and compromise the bias effect, when you don't have to? Any decent GL-5 dino non-FM fluid will work, and it will work with the maximum effect in the helical gear device.
