quote:
Originally posted by Jimbo:
Sorry, but I have to disagree on both counts.
Turbos, especially intercooled ones, increase efficiency by extracting wasted heat energy from the exhaust gasses.If correctly designed, the drop in compression ratio in spark ignition engines is small and there is still a net gain in overall efficiency.
I disagree with you on that point. The forced induction S.I. engines almost invariably show a poorer Brake Specific Fuel Consumption than their naturally aspirated counterparts, which, by definition is thermal efficiency.
And in the real world, which is predominantly throttled driving, the lower compression ratio gives you a lower expansion ration, and poorer efficiency under that regime also.
Pull out some BSFC maps for speed and load, and see for youself (Internal Combustion Engine Fundamentals by J.B. Heywood has such maps).
Similarly, turbo diesels generally show lower BSFCs through their operating range.
Without turbocharging or turbocompound, a related technology, piston-engined airliners would never have been able to fly thousands of miles without refuelling stops.
I purposely left turbo-compounding, as it's applicable to naturally aspirated engines as well as forced induction.
Forced induction in aircraft engines is predominantly to get them breathing sea level (or higher) pressure air at altitude.
This gets back to the argument that a small turbo engine CAN use less fuel than a large naturally aspirated engine (at a lower thermal efficiency for the engine).
If an aircraft needed 1000hp at cruise speed, it could be obtained by a 10 litre engine at sea level. At altitude, it might need a 25 or 30 litre engine (physically more massive), or have forced induction, allowing the 10 litre to breath sea level air at oeprating height.
Turbocharged deisels typically have a 16:1 compression ratio vs above 20:1 for many NA diesels.
Generally, the 16:1 are direct, rather than prechamber diesels, which further reduce pumping losses and heat loss to coolant, gaining efficiency.
