Originally Posted By: wgtoys
I've been changing the fluid every 30k miles on our '03 V-6 Accord (which did have a factory rebuild installed at 35k miles under warrant due to a leaking case).
We are now at 180,100 miles on the car, 145k miles on the transmission. It still shifts perfectly. IMO part of Honda's problem with this generation of transmissions is that the factory fluid was not all that great in 2003 AND they specified 120k miles for the first transmission fluid change. Considering the cost of transmission fluid vs. the cost of a transmission, I elected to be much more conservative. So far that has been a good choice.
Since then Honda has gone to a supposedly 100% synthetic based transmission fluid, but I still do the every 30k mile routine.
Causes? Fluid is one. Like an aircraft accident, often many causes contribute. Little the owner can do about it outside of changing ATF and not driving it.
Honda transmissions then had poor flow to third gear clutch, too rough steels in clutch packs that abraded clutches, weak clutches, internal ATF filters and screens that cannot be changed without taking the transmission case apart, and as a separate problem, lack of lube to 2nd gear. Clutch wear particles clogged internal screens and filters because clutches wore too fast. ATF did not flow where it was supposed to. Z-1 had too much friction modifier with too much slip and too much clutch wear.
Honda transmissions then and much more recently had overheating torque converters due to low pressure to hold the TC lockup clutch disengaged when at idle. Possibly due to leaks or intentionally low pressure at idle to improve fuel economy. TC clutch drags, overheats, wears, sends particles through and clogs the transmission screens and filters. Only one or zero of these filters is external to the case. No bottom pan to remove to change the internal AT filter. Only way to change most of filters and screens is open the trans case.
All these factors and probably more contributed to the terrible early failures of Honda transmissions. Had one myself. Breakdown prone transmission is just one of the issues that made it an troublesome expensive vehicle to own. Trans failed early even after changing the ATF every 10k miles. Used that very bad Z-1 with too much friction modifier when plain old Dex 3 would have been better. Dex 3 has less friction modifier. Flash point of Z-1 was lower than temps found in Acura TL transmission in a Honda investigation. Honda fanbois then said your trans will die if do not use Honda fluid. Wrong.
