Originally Posted By: UltrafanUK
3/ CORROSION, too much Moly can increase corrosion rates (Big issue with older diesels), hence some engines must not use an engine oil with Mo in it. Castrol GTX is a good one for such engines.
Under what circumstances might this happen? Is the Mo in 4 litres of Redline & 1 can of LM mos2 of sufficient concentration to cause harm?
I don't think so, as it was Cummins that warned against the use of oils with Moly in them, as it resulted in actual corrosion related failures:
http://www.cumminsforum.com/forum/436983-post11.html
That issue was caused by the use of cheap forms of Moly, not the real German made McCoy Moly!
The issue was the wrong type of Molybdenum Compound, called Molybdenum di(2-ethylhexyl) phosphorodithioate.
It was found to be a great friction reducer in hydraulic systems, but not in diesel engines.
The current chemistry in commercial engine oils is Molybdenum di-n-butyldithio-carbamate in a BALANCED formulation.
