Originally Posted By: bobbydavro
Originally Posted By: UltrafanUK
Originally Posted By: NHRATA
Is synthetic oil basically just for extended oil change intervals? Are there any real benefits to using a synthetic over a good conventional or synthetic blend if you plan on changing your oil at 3000 miles?
If by synthetic you mean HC (Hydro Crack), then there is almost no difference between a good major brand conventional like Castrol GTX and an HC synthetic like Castrol Edge, IF you change every 3000 miles AND don't live in the Artic where you really do need an 0wXX oil.
Now if you are talking about the real McCoy full synthetics, like Liqui Moly Synthoil or Shell Ultra, then the only difference is that they do keep the top end a fraction cleaner and resist high temp shearing slightly better. In reality the latter is only important in turbo charged engines.
The most important thing about any engine oil that is not pushed to the extremes of an extended OCI, or fried in a hot turbo at redline RPM, is the quality of the additives included in the oil.
Why would a group 4 mean a cleaner cylinder head?
Turbos aren't really an issue anymore. Piston rings run hotter
Group 4 or group 3 plus (Gas to liquids technology) base oils are less contaminated and act as natural solvents. To give you a practical example, Ultra 0w40 will keep the rings cleaner than M1 0w40 or Edge 0w40 (The test data was published by Shell and none of the major players could deny it). A true group 4 synthetic seems to produce the same results, even though HC synthetics like M1 contain more detergents.
My own UOA results indicate there is no difference between the performance of Shell Ultra 5w40 and Liqui Moly 5w40, so I just use the former as it's cheaper.
Turbo temps vary from engine to engine, with Porsch and Subaru as known hot runners that will chew up a conventional oil in high temp shearing terms if the car is driven hard. The turbo is of more interest than the rings, because it will fail before the main block if the oil feed line suffers from varnish or the oil itself degrades. That's why I'm real fussy about oil type for a turbo charged engine, but not too concerned if it is a normally aspirated one, although some VVT (variable valve timing or cam phaser) units are also rather sensitive in oil terms.
I would point out to the 3K OCI addicts, that doing too short an OCI can cause more wear than one based on a series of UOA results. My own TDI has to suffer a lot of short tripping, so I guessed at an intial 10K km oil change with 20K km oil and filter changes (The recommended max). I was very surprised to find out that the Fe and Al figures were far better per km with a longer 17K km oil change. So I'm now doing 20K km oil and filter changes.
The reasons why longer oil change intervals are often better are rather complex, as they relate to the interaction of new oil with old residual oil, in addition to changes in oil filter efficiency. To confuse matters, changing the oil type too often between conventional and full synthetic is not entirely good news either.
