Diagnosis: All wear levels appear within acceptable limits for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Viscosity within specified operating range.
Action: As oil already changed, resample at next recommended interval to monitor and establish wear trend.
Code:
DATE SAMPLED 06-Nov-15
DATE RECEIVED 19-Nov-15
DATE REPORTED 23-Nov-15
TIME ON UNIT 27127
TIME ON OIL 7004
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE SAE 5W20
OIL ADDED None
FILTER Changed
OIL CHANGED Changed
Metals (ppm)
Iron (Fe) 10
Chromium (Cr) 1
Lead (Pb)
Copper (Cu) 2
Tin (Sn)
Aluminium (Al) 3
Nickel (Ni) 1
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 7
Potassium (K) 1
Additives (ppm)
Magnesium (Mg) 757
Calcium (Ca) 1106
Barium (Ba)
Phosphorus (P) 726
Zinc (Zn) 839
Molybdenum (Mo) 80
Boron (B) 51
Contaminants
Water (%)
Coolant No
Physical Tests
Viscosity (cSt 100C) 8.5
Physical / Chemical
Base Number (mgKOH/g) 5.1
Code:
TIME ON UNIT 27127
TIME ON OIL 7004
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE SAE 5W20
OIL ADDED None
FILTER Changed
OIL CHANGED Changed
Metals (ppm)
Iron (Fe) 10
Chromium (Cr) 1
Lead (Pb)
Copper (Cu) 2
Tin (Sn)
Aluminium (Al) 3
Nickel (Ni) 1
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 7
Potassium (K) 1
Additives (ppm)
Magnesium (Mg) 757
Calcium (Ca) 1106
Barium (Ba)
Phosphorus (P) 726
Zinc (Zn) 839
Molybdenum (Mo) 80
Boron (B) 51
Contaminants
Water (%)
Coolant No
Physical Tests
Physical / Chemical
