I recently bought a 2016 F150 with the 5.0L V8. I plan on changing out the factory fill early. Maybe around 1000 km. Then at 5000 km and again at 10000 km for my first three changes. At that point I'll be trying to follow the oil life monitor. I'll be using Pennzoil Platinum 5w-20 and Fram Ultra XG10575 filter.
Is it ok to change that early and to a full synthetic right off the bat? Do I have to worry about seating the rings with conventional oil? No issues with a synthetic oil for break in? I assume it comes with semi-synthetic from the factory.
This 5.0 is quite an improvement over my 2007 5.4L. Much smoother and more powerful. Even with 3.55 gears
