C charger Joined Apr 11, 2013 Messages 8 Location Deer Park, WA USA May 19, 2016 #1 Another boring run on a thirsty 3.6R motor. Approx. 3/4 quart consumption during run. Report http://imgur.com/11RTXDi Prior conventional run
I Indiana79 Joined May 7, 2009 Messages 59 Location central pa May 21, 2016 #2 76 is a good oil. I have been using It in my 5.4 ford truck. At $26 a case it's a good price too.
Al Joined Jun 8, 2002 Messages 20,216 Location Elizabethtown, Pa May 22, 2016 #3 You are throwing away good oil. If you chose to..you could easily do 10K miles. Last edited: May 22, 2016
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia May 22, 2016 #4 Great motor and great used oil. You could defy factory OCI's further, and I would've considered a 7K/10K mi OCI
B bigt61 Joined Feb 12, 2013 Messages 3,117 Location Virginia May 22, 2016 #5 Yeah, great #'s - you could go longer - usage is normal IMO.
Y Yup Joined Mar 15, 2015 Messages 478 Location MN May 22, 2016 #6 Originally Posted By: charger Another boring run on a thirsty 3.6R motor. Approx. 3/4 quart consumption during run. Report http://imgur.com/11RTXDi Prior conventional run That's not consumption. My Honda sucks down 0w20 at about a quart per 2k. Which is why I run 5w30 or 5w40 (doesn't hardly use a drop) during the non winter months.
P Phishin Joined May 1, 2012 Messages 2,925 Location Indiana May 23, 2016 #7 Great report!! Did you change the air filter? I see your sodium went down a lot on this report, and so did your iron levels. Can you attribute that to anything? Here is my UOA on our 2009 Subie with the 4 cylinder. I used MOS2, but ran with M1 5w40 TDT, instead of SuperTech. My 2009 Subie UOA with LM MOS2 Last edited: May 23, 2016
