Got a bit of an odd situation here... a couple of months back, I replaced the head unit in my van with a cheap aftermarket one. I did this purely because I wanted an AUX input. However, I noticed upon installation that the radio reception is terribly fuzzy and full of static in urban areas (closer to Detroit). Many of the local radio and TV stations broadcast from within the city, or just outside of it. You'd think that being close to the transmission point would help, not hurt. Antenna wiring is fine, and securely in place in the head unit. Then I got to thinking of something...
The OEM radio has a metal chassis that connects to the metal dash support. The aftermarket radio also has a metal chassis, but because it sits inside of a plastic adapter, it does not actually touch the metal dash support. The only grounding that is present is through the negative wire in the harness. Should I add an additional ground between the head unit directly to the dash support? I don't recall having this issue with aftermarket head units in the past. FWIW, others have commented online about poor radio reception with the model as well. Again, it isn't range that's an issue; it's when I'm in close proximity to the broadcasts that the signals get full of static.
