My 2012 Accord EX-L has the Taffeta White paint job, this is a single stage paint job from the factory. I just wanted to share my experience regarding staining that I experience, also wanted to see if any of you have experience this with your cars as well. My car is outside 24/7 and when its not raining I like to keep it parked under trees to avoid the sun and resulting UV damage. If the car is parked under a tree during a rain storm, the water running down the leaves and branches collects grime, then eventually falls on my car. I live in Florida so shortly after the rain storm the sun is back out and it will quickly dry the water and grime and this will bake on the paint. These stains are very hard to get off the paint. I have to use quite a bit of pressure with a microfiber mitt to get even a little bit of the stains off. Is this just the nature of the beast with single stage paint jobs as they don't have a dedicated clear coat? Its just very frustrating to spend all that time detailing only to still have stains on the paint
Have any of you experienced this? I can get out the polish/compound and remove the stains, but this also removes paint and this paint is super this as it is!
