Vehicle is a 1997 GMC k1500 5.7 Vortec. My A/C is marginal at best (A/C system was recently been overhauled), and I think it could be a significant amount colder if I block off the heater core that runs hot coolant through the cab via a vacuum operated bypass valve that operates when "Max A/C" is selected. From what I have read, some earlier models have this feature already built in. I have been looking at other sites and forums that have done this, specifically these:
http://www.dieselwarden.net/ford/coolbypass.html
http://www.ford-trucks.com/forums/957375-yet-another-mod-done-pic-heater-core-bypass-valve.html
What I need help with are the vacuum lines. Coming out of the passenger side firewall are a bunch of wires. Which one is the vacuum line for "Max A/C"? I believe that line actuates the heater blend door. If I can find the line for max A/C, I can place a T fitting on it and run it to the bypass module which would keep the heater core from circulating 210* coolant through the cab with the A/C on.
A closer view of the wires.
Thank you.
Thank you.
