What do you look for when you get under the car?
CA, USA
Just got a set of used steel ramps. Look old but hardly used. This week I want to put my cars up on them to try it out. I have heard some of you talking about one advantage of changing your oil, is that you get to see what your engine is like, and check for any problems. That's fine, I'll give it a shot. When the cars are up on the ramps, I'll go ahead and take a look below.
Only I'm not sure what to check for. So what should I be on the lookout for? Dripping/leaking fluids is a good guess. Anything else? If nothing else, I'll at least have a mental picture of what the car should look like, so when I do this to change my oil in a few months, I have something to compare it to.
I never look for anything specific. I just poke around. Problems will present themselves.
I suppose if you want specifics, you can check suspension parts to make sure they're tight, and as you said, check for fluid leaks.
Suspension bushings, leaks, heater hoses, rack and pinion leaks, brake hoses and connections, CV boots, etc.
I check for leaks, the condition of the CV joints, exhaust, tires, suspension, rust (living in the rust belt), gas lines, etc. Just give it a good look over since I don't get a chance to see from that perspective much.
I would much rather have my own eyes looking for trouble than trusting a oil change "tech" keeping it in check. I keep my vehicles for a long time, I try to either avoid trouble or know in advance when something needs to be done.
If something looks strange/wet/out of place, and you don't know what the issue is, do the research on the forums to look for problems. Almost all makes have on line forums now, even my low production electric. Many times the same issue comes up over and over on any given model.
My $0.02
Absolutely true. I have made good (occasional) use of forums dedicated to my vehicles.
Chock the rear wheels and set emergency brake, and if possible have a set of jack stands under the car for the first few uses to make sure the ramps are good.
Using a BRIGHT light, examine everything in detail. Be sure to wear safety glasses/goggles. Getting fluid, dirt, grease, etc. in your eyes is no fun at all.
Right...it's not so much what to look for other than leaks etc, but what has changed since the last time you looked at it....kind of like a trend with a UOA.
Excess rust, drips, crumbling bushings, frayed/worn hoses and wires, torn boots on CV and ball joints, nests from critters.
It might be good to take a quick photo for future comparison.
When under a car I look for leaks, rust, condition of brake lines, hoses, shocks, bushings, rubber parts, exhaust system, etc.
A lot of modern cars have aero shielding under the front 1/3 or so. Look to see if it's intact and see how the fasteners come out as you may have to remove it to do the service.
Look for rust streaks.
Look at the inside-wall on the tires. You'd be amazed at the cuts and bruises that are never seen until you get under there ...
I use jack stands instead of ramps.
I check for leaks, look at rubber boots and bushings, check electrical lines, check hoses. Then I check suspension for ah abnormal play.
Minor things I've found: plastic bag wrapped around an axle, broken clips and a dangling abs sensor wire, (don't know the name of this) torn rubber boot covering a strut, leaking shocks, leaky oil pan, missing plastic push pin clips and dangling splash shields.
paulri,
First of all, it seems like you should get acquainted with the process. Safety trumps all other. Then a very minor mistake, it is good knowing, can take all of your hard work and make it seem counter-productive.
