update:
installed this thing last sunday, of course it was 85-90 F with humidity being higher.
It's the commdeck one, where the cable runs through the roof underneath it. It's a nicely thought out piece, and it works. Took about an hour or so to get it installed to our liking, mostly because of the heat.
here's the review:
They give you all the installation hardware, minus the screwdriver, razorblade, and sealant. The only downside is, per their instructions only 1 of the #8 wood lag screws will bite into the truss of the roof (underneath the shingles and plywood). Per instructions, a total of 5 #8 screws are used to secure the plate to the roof. Fortunately, I never follow instructions to the letter.
The plate gets centered over a truss (the 2x6 or 2x8 you see in the attic) and the hole for the cable is off to the side of that. So the other screws around the plate will only hit plywood. I guess this is to please the contractors who want to install this thing in less than 5 minutes.
There are only holes in the top half of the plate for the screws, because when you install it you have to cut out some shingle and slide the plate under them. The shingles lay over only the top half of the plate, where all the mounting holes and screws are. So if you want a second screw in the center of the plate, it'll have to be on the bottom side and it will be exposed and be more likely to cause a problem in the future.
The way to do it is get at least 2 1/4x20 bolts, 4 at the most, 2" long or however long is needed to reach the inside, and some large fender washers for the bolts on the inside. Use these on the sides of the plate for additional holding power. Now for the overkill part, pick up one of the aluminum (maybe zinc coated steel) pieces of metal from home depot, I think 1/8" thick or 18 gauge, 6' long, 1" wide with 3/8" holes all down it. It's easily bendable, so that was used to wrap around the truss in the attic to the 1/4 bolts coming in on each side of truss. We only used 2 bolts, and used the included lag screws for the other 2 side holes. There is no way this thing is coming off the roof. We also used rooftop sealant/caulk to glue the shingles back down and also seal the whole plate, in addition to the neoprene washers that come with the mounting screws. I "know" this thing will not leak.
And you can also remove the dish. The commdeck is a 2 piece thing, where the mount gets fixed to the roof and the dish gets fixed to the cover of the mount. Then the cover gets bolted to the mount. Just take the dish off the cover and plug the wholes with the neoprene inserts that come with it. Then you're left with a small black, or brown, box on the roof 2" high which looks like a typical vent.
