Originally Posted By: SHOZ
I've been using Toyota inserts on my Gen Coupe. They last quite a while and I like the OEM wiper aero blade. But the Accent needs them. I seem to have the original blades but no inserts. Bought some Bosch Icons last fall but they just look unfinished, like a covering tab should have been used.
I've been using Nissan inserts(refills), and keeping the original aero blade. Far cheaper than a OEM blade(or a unfinished aftermarket, pass wiper is not even available outside dealer)
The inserts come with the metal springs, and held with retaining clips you remove while installing into wiper assembly. The OEM rubber is Japanese, not Chinese like you find in aftermarket.
