Originally Posted By: Brybo86
JHZ, how does the hybrid mode function?
What I mean is when initially started and operating in battery assist mode the engine is still cold?
Or does the computer run the engine until it is up to thermostat temp? before using battery
if it works like the first scenario i can imagine that the engine, when being used, is running "rich" or in cold start like conditions. potentially allowing more fuel to wash down cylinder walls
I wonder if a honda dealer could make the car run the engine longer before going into max battery assist mode.
Hybrids are all about keeping the engine off and recovering momentum to reuse.
Efficiency (fuel economy) is all about how you run the engine. As a result, hvac is the biggest determinant. If heat is needed, the only way to get it is to call for heat from the engine.
It takes about 200 Wh/mile for an EV to transit. A hybrid has a small battery, around 1.3kWh, and its operations are optimized for very small/short cycles. But turn the car on, any weather, with no heat and you can drive a ways in EV mode. AC is electric, so it draws energy down underway too...
So have no heat or AC on, and you can drive to decent speeds (~45), until the power requirement demands the engine.
If it's really cold, the car will start the engine, idle it for a it, then turn it off. Then you can drive in EV mode until the battery charge drops too low... But... If the heat is on, and hvac is calling for heat, then it will run the engine until the coolant is around 180F.
Regular cruising on the highway will see sustained coolant temperatures like any other vehicle - 190-200F. But there's a lot more operations where the coolant is more like 180F just due to the duty cycle of the engine running in non-highway use.
