The last oil change Blackstone reported everything good except about 2+ percent gasoline in the sample. The dealer blamed it on climate conditions, should have changed at 5000 miles (Ford recommends 10,000 miles or 1 year), did I do a lot of idling, was I making a lot of short trips. This was the 3rd oil change at about 20,000 miles. 6000 miles on the this change. The first 2 samples reported no fuel in the oil. I did that change about the time the dealer did a emissions recall on the evaporative system. My driving pattern, etc has been the same since day one. What's different? the emissions recall work. They reprogrammed something. I think that's the problem. I began thinking if a little bit of fuel showed up in the sample, that means a lot more fuel has been going into the crankcase. I am going to send another sample at 1000 miles to see how much is in it. The dealer questioned the accuracy of the oil analysis. Does Blackstone still have a good reputation? Changed ownership?
